Flexipads Shaped Foam Sanding Block 70 x 125mm
504576
In stock
- Useful shaped 70 x 125mm blocks for hand sanding
- Soft and flexible for sanding contours
- Lightweight soft foam with hook and loop backing
Customers Also Bought
Soft shaped sanding block utilise 70 x 125mm quick change hook and loop backed abrasives. Extremely comfortable to hold and excellent for sanding both flat or gently contoured surfaces. Very convenient for hand sanding as you can quickly swap abrasives as you work through the grit types.
