freud TCT Saw Blades Thin Kerf - 165mm x 1.7mm x 20mm
From £25.55 £21.29 was £28.38 £23.65 Save £2.83 £2.36
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Thin 1.7mm kerf for cleaner, faster cuts with reduced effort
  • TiCo teeth for maximum sharpness and durability
  • Perma-SHIELD® coating reduces friction, corrosion and resin build-up
This freud blade has been designed for use in hand held circular and plunge saws. It delivers optimal cutting performance in a wide range of wooden materials
The extra thin kerf provides a high quality cut, requires less effort and reduces loading on the saw’s motor. The blade's extra thin kerf reduces the amount of material removed, reducing the time taken for a given cut.
The blade features Perma-SHIELD® non-stick coating. This reduces friction, protects against corrosion and prevents resin from sticking to the teeth.
The teeth are TiCo (titanium cobalt carbide), they stay sharper for longer and extend blade life however tough the application.
Laser-cut expansion slots lower vibration during use and reduce noise.
