More deals added in
Have you clocked our Christmas Countdown deals?
From £309.28 £257.73
Available to Backorder
- dispatch estimate is within 1 week. Delivery info
  • Designed for all types of coating including high solid materials
  • Perfect for use in high volume production settings
  • Compact and lightweight, the ergonomic design is comfortable for extended use
Customers Also Bought
  1. Fuji Spray LX-20 HVLP Gravity Spray Gun
Total:
£2,069.22 £1,724.35
The Fuji Spray LX-20™ is a general purpose HVLP spray gun perfect for all types of professional spray finishing. It can handle with ease all types of coatings including high solid materials. This spray gun is designed for use in a production setting.
The LX-20™ spray gun has been designed to replace conventional high pressure spray guns. It is supplied as a gravity feed model with a 600cc cup. Fuji Spray HVLP compressor spray guns are well known for higher transfer rates. It is especially suited to wood finishing and any fine finishing application.
The gun is compact, lightweight and easy to handle. The ergonomic design allows the spray gun to feel comfortable in the user’s hand for extended periods of time.
The LX-20™ is also easy to operate employing the same familiar controls as any conventional spray gun. The fan pattern control offers precise adjustment reducing overspray and waste. Fan pattern size is adjusted with a simple, yet effective side mounted control. At a spray distance of 8” the fan pattern size ranges up to 13”.
Supplied with a fitted 1.4mm air cap; 1.2mm and 1.7mm air caps are also included in the kit.
Fuji Spray LX-20™ HVLP technology complies with environmental regulations for HVLP. The added benefit provides considerable savings in material compared to conventional high pressure spraying equipment. LX-20™ technology also allows for little to no dilution for most coatings. This allows for spraying finishes as per the manufacturer’s recommendation. The LX-20™ compressor spray gun offers the same benefits of HVLP as our turbine guns.
A conventional piston compressor of around 5hp (3.75kw) should develop enough airflow for this spray gun; please check you machine's specifications.
  • Little to no dilution required for most coatings, saving time
  • Optimised air cap design results in soft spray pattern and outstanding atomisation
  • 100% stainless steel fluid passages, suitable for waterborne and solvent based finishes
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
