Axcaliber Pack Of 5 Bandsaw Blades For AT3352B
720668
From £93.18 £77.65
1 Review
Buy two Axcaliber Bandsaw Blades, get cheapest blade free! Add two or more to your basket and use code: AXBB25
  • Pack of 5 x 3,352mm bandsaw blades
  • For the AT3352B bandsaw
  • Pack comprises 1 each of:
  • 1/2" x 6 tpi Ground Tooth
  • 3/8" x 4 tpi Ground Tooth
  • 1/4" x 6 tpi Ground Tooth
  • 3/4" x 3 tpi Ground Tooth Freshcut Blade
  • 3/4" x 4 tpi Ground Tooth Freshcut Blade
A pack of 5 x 3,352mm bandsaw blades for the AT3352B bandsaw. Comprises 1 x 1/2" x 6tpi GT, 1 x 3/8" x 4tpi GT, 1 x 1/4" x 6tpi GT, 1 x 3/4" x 3tp Freshcut, 1 x 3/4" x 4tpi Freshcut.
Ground Tooth blades have diamond ground super sharp teeth and work extremely well in all wood giving a high feed rate with exceptionally high quality finish and clean cut and long life.
Freshcut 37 GT Straight Cut bandsaw has precisely ground diamond super sharp teeth with a light set which gives a narrow kerf and reduces the waste produced whilst the hook configuration provides maximum penetration. Perfect for ripping all types of timber, producing veneers and boards.
British Made British Made
5.00 1
