In any workshop space is a premium and being able to move items not in use out of the way can create extra vital space. These quality pressed steel swivel castors can add mobility to benches and machinery.
The castors have a top plate fixing with slightly elongated fixing holes for screws or bolts. The grey thermoplastic rubber tyres are fitted to a polypropylene wheel with a plain bore. The brake, when applied, prevents both the wheel from turning and the swivel from rotating.
Universally useful items with applications in all sorts of areas, not just for moving machinery around. Handy to make ‘dollies’ for moving heavy items, large flower pots etc. Add to your workbench and work outdoors in the fine weather.
Wheel diameter 75mm, width 24mm, overall height 100mm, top plate 65mm x 65mm, load capacity 50kg.
