Affordable Workshop Tools Worth Knowing About
Finding tools that offer a great balance of price, quality and performance can sometimes be easier said than done. When you're building your workshop on a budget, it's important to choose tools that are versatile, reliable and genuinely worth the investment. But, fear not, we've rounded up some of our favourite workshop staples that deliver where it matters, without costing a fortune - affordable workshop tools worth knowing about, if you will.
A machinery triple threat
Let's start with machines! The Perform PD1400B Bandsaw makes a great all round, handy machine for various woodworking projects. Easily cut curves, straight lines and thin or thick materials, you can get a lot of use for your money with a bandsaw. At an affordable price, the Perform PD1400B Bandsaw is a great start to kitting out your workspace. Plus, pair it with the Axminster Tool and Machine Wax; when buffed into the machine table, the wax greatly reduces friction between timber and the surface of the table, ensuring smoother and higher quality results. Used regularly, it helps resist corrosion too! A perfect cupboard staple for your workshop.
The Axminster Happy Fingers Feather Board is a workshop safety accessory that improves control and accuracy. By applying consistent pressure against the machine work fence or table, it helps keep your workpiece in position, reduces movements and minimises the risk of kickback. Use this on your machines, or router tables for smoother, more precise results!
Top power tool pick
A combi drill is one of those highly useful power tools that deserves a place in any workshop. The Einhell TP-CD 18/80 Li-i BL Combi, 4.0Ah Battery, Charger & Case is a versatile choice, combining drilling, screwdriving and impact drilling in one tool. With an 80 Nm torque output and up to 28,800 impacts per minute, it’s well equipped for everything from everyday workshop tasks to drilling into tougher materials such as stone and concrete. Its brushless motor provides increased power, longer runtime and durability, while the included 4.0Ah battery is part of Einhell's Power X-Change system, meaning it can be used with a wide range of compatible tools.
Free Extras
Einhell TP-CD 18/80 Li-i BL Combi, 4.0Ah Battery, Charger & Case£99.98£106.98 Save £7.00
Hand tool must-haves
Hand tools can make all the difference in the workshop, whether you’re tackling work-holding, adding decorative details, sawing, routing, sharpening or making those final finishing touches. Versatile and practical, they’re essential for getting the job done and worth having close to hand in every toolbox. This selection ticks off many tasks that regularly occur in woodworking.
Measure twice, cut once!
We all know the golden rule in woodworking - measure twice, cut once! For the small amount of time it takes, accurate measuring and marking can make a big difference to your project results. These four essential tools make measuring and marking quick, easy and hassle-free. Rules ensure accurate measurements, pencils for marking with precision, and an angle meter for blade or table positioning, mitre and bevel work, machinery set up and more.
Handy extras...
Now it's time for a couple of random tools that are everyday go-to's that make the world of difference.
Lightweight and easy to move around, the Perform Quick Bench makes an excellent portable workstation. Chuck a stable top onto the bench and you'll have yourself somewhere to place your tools and machines in no time! When you're finished, simply fold away.
A screwdriver set is always handy to have around - no explanation needed!
A mask - essential in any woodworking task to make sure you're keeping yourself safe. The JSP Force 8 Reusable Half Mask provides effective protection against dust particles. Its reusable design makes it a practical choice for repeated use in the workshop.
Finally, a glue is a must-have for any woodworker. Titebond ensures exceptionally strong bond wood-to-wood joints, has a longer open time and higher viscosity than conventional PVAs, and will maintain integrity at lower application temperatures. This makes assembly easier and less fraught.
Finding affordable workshop tools can be challenging, but we hope some of our favourites will soon become yours too! A few well-chosen workshop staples can make a real difference. Get the versatility to tackle a variety of jobs, without breaking the bank.
