Bosch Campaigns | All Things Bosch
Over the years Bosch have unveiled some great campaigns for power tool lovers around the world. Read on to find out more about the Top Bosch Campaigns from 2020 plus a select few that are still worth shouting about!
X-LOCK
Firstly, the Bosch X-LOCK system will save you precious time, effort, and money through more efficient working. As one of Bosch's most innovative product lines, enjoy a new generation of Bosch corded and cordless angle grinders as well as multiple discs, available in both 115mm and 125mm versions.
There's a whole host of features and benefits to this new system but in short, it's incredibly convenient and easy to use. X-LOCK accessories lock grinder accessories down tight and there's no negative effect on your grinding experience. Learn about the features and benefits of the Bosch X-LOCK system.
Carbide
Next in our list of Bosch campaigns is all things carbide. Due to the fact carbide boasts excellent heat resistant properties, all Bosch carbide accessories are extremely hard wearing and durable, even in the toughest of conditions.
Sabre Saw Blades
Carbide Reciprocating Saw Blades succeed in materials where Bi-Metal blades quickly fail. Bosch offers a full range of carbide reciprocating saw blades which enable you to cut toughest materials, each and every time. Effortlessly cut through hard materials such as high-alloy, hardened and stainless steel, cast iron pipes or window frames with hardened screws. Plus, with the Bosch Endurance series you'll enjoy much more mileage from there before you need to replace them.
Brushless Rules
Let the challenge begin with the durable and highly efficient Bosch Professional Brushless drills. With Bosch's newly updated range of 18V brushless combi drills you can select the performance level you require, without losing brushless efficiency. Unlike traditional DC tool motors, brushless motors do not contain brushes. This makes them maintenance free. They are also significantly more efficient and powerful, resulting in a tool that has up to 100 % longer lifetime and 30% longer runtime per battery charge.
Want to find out more? Read our short article about Bosch's range of 3 tier performance range of brushless 18V combi drills.
18V Professional Tools
Next, Bosch 18V tools meet the highest standards in speed and precision to provide exceptional results, onsite or at home. From combi drills, angle grinders, mitre saws and much more, Bosch 18V tools combine power and fast charging technology to take your work to the next level. Read our helpful guide on 18V professional tools from Bosch and browse a selection of our favourites!
Twin 18V Kits
When two is better than one! In terms of Bosch Twin 18V kits, we offer this fantastic kit, available for purchase.
Bosch GSB18V-85 C Combi & GDX 18V-200 C Professional 18V (5.0Ah)From £479.98 £399.98
Bosch ProDeals
Finally, for a limited time only, buy a selected Bosch Professional 18V tool and get a second product from a defined range free of charge! Valid 1st September to 31st December 2020. See how to claim.
Other noteworthy Bosch campaigns!
Connectivity
Next, simply connect your tools and measuring devices to the Bosch Toolbox App on phone or tablet via Bluetooth - for sending, receiving and storage of information. A small Bosch connectivity module can be bought with the tool. Alternatively, you can purchase one separately and simply slot in later. The main benefit is that connected tools and their users communicate via the free downloadable Bosch Toolbox app, which accesses a growing range of time and effort-saving aids.
Key capabilities of the Bosch connectivity system include asset management and tool location, quick tool registration and personalised settings, fault alerts, condition and usage reports, and remote control. Importantly, the system was designed to integrate new functionalities as they evolve. This puts users ahead of their competitors and future-proofs their businesses by equipping tools to benefit from continuing advances.
Starlock Accessories
Furthermore, Starlock (a joint venture between Bosch and Fein), is a patented blade mounting system that provides a very fast ‘snap in’ blade fitting. In recent years, the Starlock system has set the new standard for multi-tools and accessories. The old OIS interface was limited in blade length and oscillation angle and the OIS pins were prone to breakages.
With the 3D interface (star) and Bosch’s three different categories (Starlock, StarlockPlus and StarlockMax), Starlock’s simple click lock system is able to transfer more force and can combine longer blades with higher oscillating angles. For convenience, the Starlock system doesn’t require tools and the blades are backwards compatible with other star fit oscillating tools. Read our helpful guide to find out more about the Starlock range from Bosch.
ProCORE18V Batteries
The new generation of Bosch batteries
A new dimension of power for all Bosch Professional 18V power tools. The ProCORE18V batteries 4.0Ah, 8.0Ah and 12.0Ah are Bosch’s most powerful batteries ever. This is thanks to the latest cell technology and superior heat management.
Compact 4.0Ah Batteries
Enjoy all the power of a conventional battery but without the weight. This type of Bosch battery is ideal for all drilling and screwdriving applications where a lower weight comes in handy. Up to 39% more compact and noticeably lighter than comparable batteries of its class, the latest cell technology of the ProCORE18V 4.0Ah delivers just as much power as a standard 4.0Ah battery.
Performance 8.0Ah Batteries
Next, these batteries have the perfect balance between weight and power. As a high performance battery, whenever you need high power over a long period, this is the perfect battery to use. The ProCORE18V 8.0Ah delivers fantastic performance despite its compact size. It is 30% smaller than comparable high performance batteries which means it offers the highest energy density in its class.
In terms of power, it is comparable to corded tools of up to 1600W. The ProCORE18V 8.0 Ah offers approximately 90% more power than the previous 18 volt 6.0 Ah battery. This significant power increase is thanks to an improved cell design and measures taken to minimise internal resistances. Overall, this improves efficiency.
Next, Bosch has optimised its proven CoolPack technology even further. This means that this high-performance battery can handle higher power demand over a longer period. It also helps to substantially prolong the battery’s lifetime compared to a conventional battery. Heat dissipation from the inside out is maximised in this technology by the synergy between several components. The housing and the heat sinks in the interior are manufactured from high-density polyethylene. Both the material and the special design facilitate better heat dissipation. This aims to maximise the surface area.
Lastly, the battery is designed without any internal spacing. This ensures the heat it produces is not caught in the interior. Improved cell connectors made from copper provides lower resistances and more power as a result. The battery pack has special openings for heat dissipation during the charging process as well. This cooling feature means that the battery can be charged very quickly. The five-level LED display allows tradespeople to keep the charge level of the under control at all times.
Endurance 12.0Ah Batteries
Finally, enjoy maximum performance and run-time with this beast of a battery! This type of Bosch battery allows you to work with maximum power for an exceptionally long time. It is ideal for extreme applications as it delivers every ounce of power out of your tools. Thanks to the triple-layered cell structure of the ProCORE18V 12.0Ah, the Endurance 12.0Ah battery delivers performance as powerful as that of corded tools.
For more about the different types of Bosch batteries available, read our helpful blog.
Bosch 3 Year Warranty
Register your tools with PRO360; your free, convenient and efficient access portal for numerous services from Bosch Professional. Register once and then benefit continuously from all current and future services, e.g. the free extension of your tool guarantee from 1 year to 3 years.
Discover more…
Did you enjoy this article about some of our favourite Bosch campaigns? Why not learn all about the Bosch GCM 18V-216 BITURBO Mitre Saw? Ideal for a wide variety of applications, this super strong mitre saw is a fantastic choice wherever you are working. With comparable power of an 1600 watt corded machine, the BITURBO tool has been specifically designed and optimised to work with the Bosch ProCORE18V battery platform.
Get in touch!
If you love the Bosch brand, we’d love to hear from you. Comment below or send us a photograph and tell us all about your recent Bosch purchases or favourite Bosch tool. Alternatively, get in touch via our social media platforms. Find us on Facebook or connect with us on Instagram using #boschcampaigns to @AxminsterTools.
