Beat The Boredom | Woodworking Projects for Kids | Branch Wreath
Get in the festive spirit with our next Beat The Boredom project! Designed with children in mind, if you’re looking to spruce up your home or door, this decorative branch wreath is perfect for any space!
What you'll need
Branch Wreath
Brighten up your home with our decorative branch wreath project for guaranteed smiles!
Part 1 - Cut rounds
Select some branch material of differing thickness and cut rounds. To do this, we used a bench hook and a tenon saw. You will need approximately 25-30 rounds depending on the size of your wreath.
Part 2 - Sand
Using an abrasive, sand on both faces of the wooden rounds.
Part 3 - Arrange
Arrange your rounds around a side plate to keep the circle even. You may have to swap the sizes a little to make each of the rounds sit snug against each other.
Part 4 - Glue
Now for the next layer. Generously apply PVA glue to the back of the rounds that will form the top layer. Stick down and bridge two of the loose bottom rounds. In our example, we used the Osmo glue because of the strong initial tack. Repeat until all the rounds are stuck together to form the top layer of your wreath.
Part 5 - Decorate
Allow the correct curing time for the glue you have used. This is to ensure the project is stable enough to decorate. Here you have the opportunity to decorate however you like. Based on personal preferences and available resources, we used some festive ribbon, pine cones, berries and holly to decorate ours.
Win a £25 Gift Card…
For a chance of winning at £25 Axminster Gift Card, simply show us what Beat The Boredom projects you’ve completed by uploading them to Instagram, Facebook or on to our Community Forum.
Snap It
Take a photo of your project.
Tag It
Use the #BeatTheBoredom hashtag and upload it to one of the following;
- Instagram or Twitter and tag @axminstertools
- Facebook and tag @axminstertools
- The Community Forum under the Beat The Boredom post
Discover more...
If you've enjoyed reading this article, keep an eye out for our next woodworking project for kids as part of our online Beat The Boredom series. Watch this space for more details! Furthermore, why not take a look at all of our previous projects below?
Get connected!
Follow us on Instagram and Facebook to stay up to date on all the latest from our Beat the Boredom series. Connect with us using #BeatTheBoredom to @AxminsterTools.
