Stay sharp with Tormek - but which Tormek model do you need?
Tormek's sharpening machines are designed for every tool sharpening job where the finest edge is needed. The innovative design is appreciated worldwide for its unbeatable versatility, accuracy and ease of use. Undoubtedly, it's the number one water-cooled sharpening system, so the only question is - which Tormek model do I need?
Take a look at the chart below to easily compare the Tormek T-8 Original, T-8 Custom and T-4 Original
Tormek T-8 OriginalInnovative water-cooled sharpening system with unbeatable versatility, accuracy and ease of use. Comes complete with the SE-77 Jig for you to get sharpening your square edge tools straight away. |
Tormek T-8 CustomThe Custom allows you to create a bespoke sharpening system. Choose only the grinding wheel, honing wheel and jigs that suit your needs. |
Tormek T-4 OriginalSame precision and stability as the larger models but with a compact design. Perfect for home and hobby use, or professionals with limited space. |
Package contains |
Tormek T-8 machine plus SG-250 Original Grindstone, LA-220 Leather Honing Wheel, US-105 Universal Support, T8-00 Storage Tray, SE-77 Square Edge Jig, TT-50 Truing Tool, SP-650 Stone Grader, WM-200 AngleMaster, PA-70 Honing Compound, EM-15 Edge Marker, HB-10 Tormek Handbook and Metal Plate Mount for WM-200 AngleMaster. This package relates to Product Code: 102175 further packages are available with kits for the woodturner and woodworker. | Naked Tormek T-8 machine plus HB-10 Tormek Handbook, WM-200 AngleMaster and US-105 Universal Support with micro adjust. This package relates to Product Code: 107062. | Tormek T-4 machine plus SG-200 Original Grindstone, LA-145 Leather Honing Wheel, US-103 Universal Support, SP-650 Stone Grader, WM-200 AngleMaster, PA-70 Honing Compound, EM-15 Edge Marker and HB-10 Tormek Handbook. This package relates to Product Code: 507158 further packages are available with kits for the woodturner and woodworker. |
Can sharpen most edge tools |
Motor Duty (load cycle) |
Continuous | Continuous | 30 min/hour |
Certified for professional use |
Warranty |
8-year warranty (5 years + 3 years when registered at tormek.com)Valid for professional use as well |
8-year warranty (5 years + 3 years when registered at tormek.com)2-year warranty when used for commercial, industrial, or educational purposes. |
Housing |
Precision-cast frame in powder-coated zinc. Impact-resistant ABS plastic | Precision-cast frame in powder-coated zinc. Impact-resistant ABS plastic | Precision-cast top in powder-coated zinc. Impact-resistant ABS plastic |
Scale for grinding wheel diameter |
Main shaft |
MSK-250 Stainless Steel Shaft with EzyLock | MSK-250 Stainless Steel Shaft with EzyLock | MSK-200 Stainless Steel Shaft with EzyLock |
Grinding wheel locking |
Stainless steel EzyLock | Stainless steel EzyLock | Composite EzyLock |
Honing wheel locking |
Quick release knob | Quick release knob | Hex nut |
Performance |
100 rpm, Torque 14.7 Nm | 100 rpm, Torque 14.7 Nm | 120 rpm, Torque 8.4 Nm |
Idling sound level |
54 dB | 54 dB | 54 dB |
Machine dimensions |
Width: 270 mm (10 5/8") Depth: 270 mm (10 5/8") Height: 330 mm (12") | Width: 270 mm (10 5/8") Depth: 270 mm (10 5/8") Height: 286 mm (11 1/4") | Width: 240 mm (9 7/16") Depth: 205 mm (8 1/16") Height: 260 mm (10¼") |
Machine Weight |
14.8 kg (32.6 lbs) | 9.3 kg (20.5 lbs) | 8 kg (17.6 lbs) |
Original Grindstone Wheel compatibility |
SG-250 | SG-250 | SG-200 |
Japanese Waterstone compatibility |
SJ-250 | SJ-250 | SJ-200 |
DC/DF/DE Diamond Wheels compatibility |
250 | 250 | 200 |
Tormek Grinding Jigs compatibility |
Tormek Accessories compatibility |
Want to learn more about these models and the many packages available?
Choose below for more details...
Tormek T-4 Sharpening Systems
Tormek T-4 Original Sharpening SystemFrom £439.98 £366.65
Tormek T-4 Original Sharpening System With HTK-806 Hand Tool KitFrom £627.48 £522.90
Tormek T-4 Original Sharpening System With TNT-808 Woodturner’s KitFrom £749.98 £624.98
Tormek T-8 Sharpening Systems
Tormek T-8 Custom Sharpening SystemFrom £444.98 £370.82
Tormek T-8 Original Sharpening SystemFrom £765.98 £638.32
Tormek T-8 Original Sharpening System With Hand Tool KitFrom £949.98 £791.65
Tormek T-8 Original Sharpening System With Woodturner’s KitFrom £1,059.98 £883.32
Tormek T-8 Original Sharpening System With Hand Tool & Woodturner's KitsFrom £1,269.98 £1,058.32
