Tormek T-8 Original Sharpening System With Hand Tool Kit
- Tormek T-8 Water Cooled Sharpening System
- Fully cast housing for strength and accuracy
- Integral sleeves for support bar guarantees correct alignment
Customers Also Bought
Package deal comprises the Tormek T-8 Water Cooled Sharpening System and Tormek HTK-806 Hand Tool Kit.
The Tormek T-8 sharpening system is the perfect answer to your sharpening requirements. For any professional or amateur needing a versatile, reliable and repeatable sharpening system, the T-8 should be on the top of your list. The T-8 has a 250mm x 50mm water-cooled grindstone and a 220mm x 31mm leather tyred honing wheel. Powered by a quiet 200W motor, Tormek’s unique and efficient drive system maintains constant speed, even under load. Tools can be sharpened with the Supergrind wheel cutting towards or away from the edge. The T-8 features a strong, cast-alloy casing. The mounting sleeves for the universal support are an integral part of the casting. The design eliminates the possibility of any misalignment between the universal support and the grinding wheel. The universal support bar has a micro-adjuster, which makes setting up or replicating a sharpening angle easy and highly accurate.
The Advanced Water Trough features a screw lift mechanism. You can fit it, fill it and then by simply turning the knob, raise the trough to bring the water into contact with the stone. It makes removing the trough for emptying just as simple. The T-8 includes a magnetic scraper for efficient cleaning. The unit has an NVR safety switch with a strong waterproof cover. The T-8 is suitable for use in education and other areas where an NVR switch is a necessity. The T-8 includes TT-50 Truing and Dressing Tool, SP-650 Stone Grader, WM-200 Angle Setting Guide, PA-70 Honing Paste and Dressing Oil for the honing wheel. In addition, there is a comprehensive handbook packed in a strong storage tray. The T-8 also includes the SE-77 upgraded jig for square edge tools.
New 8 year warranty (5+3)
Introducing the new Tormek T-8 extended warranty of 5 years + 3 extra years upon registration.
Packed in a high quality storage case with an opaque lid and foam insert, the HTK-806 is a comprehensive kit of 6 jigs for sharpening common hand tools. The jigs enable you to sharpen a wide range of tools such as axes, scissors, long chef’s knives, short bladed knives, carving and butt chisels, pocket knives and garden shears.
The Tormek HTK-806 contains the following Tormek jigs: SVM-45 Short Knife Jig, SVM-140 Long Thin Knife Jig, SVX-150 Scissor Jig, SVS-38 Short Tool Jig, SVA-170 Axe Grinding Kit and SVM-00 Small Knife Holder.
For more tips on sharpening please see Tormeks YouTube channel.
- Screw lift rise and fall mechanism for water trough
- Micro adjustable for complete control of sharpening angle
- Sharpens all types of steel, including high speed steel (HSS)
- Includes upgraded SE-77 jig for precise 90° edges
- 8 year warranty (5+3)
- Tormek HTK-806 Hand Tool Kit
- Kit contains:
- SVM-45 Short knife jig
- SVM-140 Long thin knife jig
- SVX-150 Scissor jig
- SVS-32 Short tool jig
- SVA-170 Axe grinding kit
- SVM-00 Small Knife Holder
- All contained in a quality storage case.
