Z-Saw Japanese Folding Pruning Saw - 210mm
- Lightweight with a narrow blade, folds into the handle when not in use
- Universal ground teeth for fast cutting action
- Die-cast aluminium handle; comfortable elastomer grip
- 210mm long blade, 0.9mm thick with a 1.18mm kerf
Japanese saws have a reputation for their clean cutting performance. A cleaner cut lessens the likelihood of disease entering the tree through the wound. This is an ideal saw for pruning fruit trees or trimming a rogue branch. Lightweight with a narrow blade, it is handy if you need to take it up a ladder to trim branches. The universal ground cutting teeth produce fast results. The die-cast aluminium handle has an elastomer grip, giving you better control and a more secure grip. When not in use the blade folds into the handle protecting the teeth. Folded, the saw fits easily into a toolbox or a deep pocket. The compact size makes it a good addition to anyone’s camping equipment. The blade locks in position when open with a choice of 2 positions for cutting convenience. The blade is 210mm long and 0.9mm thick with a 1.18mm kerf and a 3.0mm pitch. It stays sharp and cuts quick, what more can you ask for?
Blade Thickness | 0.90 mm |
EAN Barcode | 4963041180017 |
Kerf | 1.18 mm |
Length of Blade | 210 mm |
Tooth Pitch \ tpi | 3.00 mm \ 8.5 tpi |
- Standard Delivery* - £4
