TopMan Japanese Pruning Saw - 330mm
- Non-slip grip accepts extension or broom handle for better reach
- Teeth have 3-cutting edges, cuts on push and pull stroke
- Makes light work of pruning and leaves a very clean cut
Arno Pruning Secateurs - 180mmSpecial Price £44.58 £37.15 was £63.68 £53.07 Save £19.10 £15.92
This Japanese pruning saw has a curved blade and a non-slip grip. The handle is hollow (22mm) for connection to an extension pole or broom handle so you can reach those higher branches (a hole in the side is provided for a screw to secure the broom handle). The curved blade helps teeth stay in better contact with the timber for a faster cutting action. The teeth themselves have three ground cutting edges and cut on both the pull and push stroke. The saw leaves a very clean cut surface, which helps with the healing process.
480mm overall length with a 330mm long blade. Suitable for branches up to 125mm in diameter.
Blade Length | 330 mm |
EAN Barcode | 4976350210696 |
Overall Length | 480 mm |
- Standard Delivery* - £1.99
