Laguna 16-32 Drum Sander 230V
- Open-ended drum, allows 800mm sanding width in two passes
- Patented quick adjust lever reduces set-up time and boosts productivity
- Built-in digital readout (DRO) ensures consistent thickness
- Variable speed conveyor table automatically adjusts for a consistent finish
- Turbo vented dust port increases airflow to a dust collector
- Drum carriage is bolted to the base, eliminating movement
Maximise your sanding capabilities
A compact powerhouse that will maximise your sanding capabilities.
Opened ended drum
Allows 810mm maximum sanding width in two passes, enhancing the sander's versatility and capacity for larger projects.
Allows full height adjustments with one pull of a lever and finer adjustments with the hand wheel, significantly reducing set-up time and boosting productivity.
Built-in digital read out
Ensures consistent thickenesses for increased accuracy and quality of output.
INTELLISAND technology
Variable speed conveyor table automatically adjust to maintain a consistent finish, accommondating varying grain patterns and densities.
Increases air flow to a dust collector by 15%, enhancing dust removal.
Perfect feed alignment
The drum carriage is bolted to the base, eliminating movement or alignment issues.
Robust construction
Comes with a floor stand and includes a 1 x 80G wrap, ready for immediate use.
Axminster Tools Extended 2-Year Warranty
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care.
Find out moreUnlock the full potential of your machine
With the extensive range of Laguna accessories
See the accessoriesRecommended Accessories
Laguna Sander Abrasive Wraps for 16-32 Sander Pack 4 - 36gSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75
Laguna Sander Abrasive Wraps for 16-32 Sander Pack 4 - 150gSpecial Price £20.38 £16.98 was £23.98 £19.98 Save £3.60 £3.00
Laguna Sander Abrasive Wraps for 16-32 Sander Pack 4 - 180gSpecial Price £20.38 £16.98 was £23.98 £19.98 Save £3.60 £3.00
Laguna A|Flux 12 Air Filter 230VSpecial Price £389.98 £324.98 was £459.98 £383.32 Save £70.00 £58.33
The Laguna Supermax 16|32 Drum Sander is a compact powerhouse, meticulously engineered for top-tier efficiency and precision, delivering professional-grade sanding performance. This sander is brimming with innovative features that guarantee accuracy, productivity, and user-friendliness.
The open-ended drum design allows for 400mm in a single pass and an impressive 800mm maximum sanding width in just two passes, making it perfect for larger projects and enhancing the sander's versatility. The patented quick adjust lever enables full height adjustments with a single pull that can then be finely adjusted with the handwheel, significantly reducing set-up time and boosting productivity.
For consistent thickness and superior quality of output, the sander is equipped with a built-in digital readout (DRO). The INTELLISAND technology features a variable speed conveyor table that automatically adjusts to maintain a consistent finish, accommodating varying grain patterns and densities.
Dust management is a breeze with the 100mm diameter turbo-vented dust port, which increases airflow to a dust collector by 15%, enhancing dust removal when connected to a suitable dust extractor. Perfect feed alignment ensures that the drum carriage is bolted to the base, eliminating any movement or alignment issues. Additionally, a simple adjustment feature allows the conveyor to be quickly and easily aligned to the sanding head with just one nut.
When sanding stock wider than 400mm and making two passes, the index lever will adjust the conveyor to give a seamless finish. Built to last, the robust construction of the Laguna Supermax 16|32 Drum Sander includes a floor stand and comes with a 1 x 80G wrap, ready for immediate use. Experience the ultimate in sanding performance and efficiency with this exceptional tool.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Laguna 1-Year Warranty
The standard 1-year manufacturer's warranty for Laguna machines guarantees satisfactory quality, fitness for purpose, freedom from material defects, and compliance with UK regulations.
Enhance your peace of mind with Axminster Tools' optional 2-year extended warranty on all Laguna machines. This extended warranty, is only available for purchase at the time of purchasing your Laguna machine. It ensures comprehensive coverage for any defects in workmanship, parts, and materials for a full two years from the original invoice date. With this extended warranty, you can rest assured that any faulty part will be repaired or replaced at no cost to you, providing you with the highest level of support and protection on your investment.
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care. Find out more
Abrasive Roll Width | 76 mm |
Drum Speed | 1,400 rpm |
Dust Extraction Outlet | 100 mm |
Feed Speed | 0 to 3 m/min (var) |
Min Extraction Airflow Required | 1,000 m³/hr (600cfm) |
Model | Supermax 16-32 |
Nett Weight | 72 kg |
Overall L x W x H | 860 x 560 x 1,220mm |
Plug Fitted | UK 3 pin plug |
Power | 1.1 kW |
Rating | Home/Light Trade |
Sanding Thickness Min\Max | 0.8 mm to 75 mm |
Sanding Width Double Pass | 810 mm |
Sanding Width Single Pass | 405 mm |
Voltage | 230 V |
