Mafell TCT Saw Blades for MT55 160mm x 20mm
AX1038795
AX1038795
- 24 tooth 160mm for general purpose wood cutting
- 32 tooth 160mm for fine wood cutting
- 48 tooth 162mm for clean cuts in manmade or melamine surfaced board
Show more
Show less
Finest quality TCT saw blades for the Mafell MT 55 plunge saws and other circular and plunge saws that take this size of blade. These blades have a 1.8mm kerf. The 24 tooth for general purpose wood cutting. 32 tooth for fine wood cutting. 48 tooth for clean cuts in manmade or melamine surfaced board.
Blade Diameter | 160 mm |
Bore Size | 20 mm |
Kerf | 1.8 mm |
Maximum RPM | 9,500 rpm |
Plate Thickness | 1.2 mm |
Tooth Format | ATB |
