This well balanced planer is part of the Makita cordless 18V family. Based on the mains power model and giving the same performance, it has a blade width of 82mm and will plane up to 2mm in a single pass with a maximum rebate depth of 9mm. Depth adjustment is accurately controlled with a large front grip handle with scale adjusting in 0.01mm increments. The blades are protected when not in use by a small foot that drops from the baseplate lifting them clear of a surface and potential damage. Supplied as a body only, this tool takes Makita 18V Li-Ion batteries.
Please note: model number starting with letter 'D' has a 'star' imprint on the connector plate enabling full communication with a Makita battery also with a 'star'.
Battery Voltage 18 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 95 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 84 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 4.5 m/s² [1.5 m/s²]
Model DKP180
Blade Type TC Reversible
Cutterblock Speed 14,000 rpm
Max Depth of Cut 2.0 mm
Max Rebate Depth 9 mm
Nett Weight 3.4 kg (with battery fitted)
Planing Width 82 mm
Warranty Makita 3 Year Warranty (Registration Required)
EAN Barcode 88381662635
