The Osmo 220mm Floor Brush is a professional quality floor brush designed for the quick and even application of interior and exterior floor finishes. Suitable for use with water or oil based products including Decking Stains and Decking Oils, Floor Varnishes and Floor Paints. You can use it with a 23.5mm (15/16") broom handle when oiling or staining a floor or decking. The advantage of this brush is that the width covers a large area quickly. You achieve a much more even coating as you are always working on a wet edge. Coverage is more even as the brush automatically works the oil or stain into every crack and crevice. The 100% natural hair bristles produce professional looking results on flooring and decking every time. Ideal for the application of wood finishing products including water and solvent-based varnishes, polyx, hard wax and decking oils, stains and liquid waxes.
