The 20 Big Easy Jaws Extensions are designed to be used with the 16 Big Easy Jaws. Expand your maximum gripping diameter to 18 and the expanding diameter to 19.1/2. When the jaws are fully closed, the outer diameter is 18.3/4. Fully open, the outer diameter is 20. Please ensure your lathe has a minimum swing of 20 when using these jaws.
Compatible with the 16 Big Easy Jaws and the Easy Chuck.
Web Attribute Set Jaws for Four Jaw Chucks
