Easy Wood Tools
Easy Wood Tools 20" Big Easy Jaws Extensions
SKU: 113279
€195,00
  • For use with the 16 Big Easy Jaws
  • Expand your gripping diameter to 18
  • Perfect for larger bowls, hollow forms and platters
The 20 Big Easy Jaws Extensions are designed to be used with the 16 Big Easy Jaws. Expand your maximum gripping diameter to 18 and the expanding diameter to 19.1/2. When the jaws are fully closed, the outer diameter is 18.3/4. Fully open, the outer diameter is 20. Please ensure your lathe has a minimum swing of 20 when using these jaws.
Compatible with the 16 Big Easy Jaws and the Easy Chuck.
Web Attribute Set Jaws for Four Jaw Chucks
