Proxxon 60 Mill/Drill 12V & NG 2/E Mains Adaptor
- Proxxon Micromot 60 Mill/Drill Unit 12V
- Soft grip nosepiece for comfort
- Slim, easily handled and lightweight (230g)
Customers Also Bought
Package deal comprises a Proxxon Micromot 60 Mill/Drill Unit 12V and a Proxxon MICROMOT NG 2/E Mains Adaptor.
With a diameter of only 35mm and its low weight, the 12V Proxxon MICROMOT 60 has great balance and is easy to manipulate. The soft grip makes for convenient, safe handling and a tool that is a joy to use. The balanced motor with ground spindle and collar bearing make this a very smooth running machine.
This versatile workhorse lets you engrave, cut, sand, polish, grind and more. Whether you are a model builder, detail carver, tool and die maker, jeweller or artist, you will find the MICROMOT 60 invaluable. The wide range of Proxxon bits available let you work on steel, wood, non-ferrous and precious metals, glass, ceramics, plastics and stone.
It comes with a set of 5 high-quality MICROMOT steel collets (1 each of 1, 1.5, 2, 2.4, ,3 and 3.2mm). These hardened steel collets have 3 slits. The design results in an increased bearing surface, ensuring positive and accurate clamping of even the smallest shanked bits.
The tool has a standard 20mm collar for stationary use with the Proxxon drill stands MB140/S and MB 200 as well as in the universal holder UHZ.
The mains adaptor NG 2/E is a 230V to 12V unit suitable for many of the Proxxon machines. The NORYL casing is heat resistant, which is a necessity for transformer enclosures. The red LED indicates readiness for use and the PTC element (Positive Temperature Coefficient) prevents overload of the unit. A foldable tool rest provides a secure place for keeping the MICROMOT 60 at the ready.
- Smooth running, balanced, quiet motor
- High quality steel collets ensure accurate clamping
- Supplied with 6 collets: 1, 1.5, 2, 2.4, 3 and 3.2mm
- Proxxon MICROMOT NG 2/E Mains Adaptor
- Offers variable speed control
- Maintains high torque at low speed
- Tough heat resistant NORYL casing
- Foldable rest for Micromot tools
