PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The FF 250/BL is a stand alone mill/drill, and a high quality addition to the PROXXON Micromot range of engineering machines. The FF 250/BL features variable speed pre-selection from 400 - 6.000rpm with digital speed display. Speed sensors guarantee high torque also in the lower speed range. A rotational speed chart on the front of the housing shows the appropriate spindle speeds for the most common applications. The headstock swivels through 360°, and tilts 90° left and right. The mill/drill’s table offers X-Y travel, longitudinally and cross-wise respectively of 110 x 70mm, with 3 T-slots. The tool holder uses ER 16 collets.
The FF 250/BL is supplied with 6mm, 8mm and 10mm collets.
PROXXON Micromot: 2 year warranty for private use, 1 year warranty for commercial use
