Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The milling PF 250/BL is designed and built for milling and drilling on a PROXXON PD 250/E or PD 400 lathe. Both of which are already drilled accept this mill/drill head. The mill/drill’s table replaces the lathe's top slide, thus adding a compound table, with X-Y travel being longitudinally and cross-wise respectively of 110 x 70mm, with 3 T-slots. The millhead tilts up to 90° left and right. Speed can be pre-selected from 400 - 6,000rpm, the head features a digital speed indication. Speed sensors guarantee high torque also in the lower speed range. The tool holder uses ER 16 collets, the PF 250/BL is supplied with 6mm, 8mm and 10mm collets.
A rotational speed chart on the front of the housing shows the appropriate spindle speeds for the most common applications.
PROXXON Micromot: 2 year warranty for private use, 1 year warranty for commercial use
