PROXXON Voltage Tester to VDE 0680
- Indicates voltage 220 to 250V, 50/60Hz
- High-strength ABS handle, textured surface for non-slip grip
- Overall length 180mm, blade length 80mm, 3.5mm tip
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
This voltage tester gives an indication of voltage between phases 220 to 250V, 50/60Hz (up to 500Hz). The handle is high-strength ABS, with a textured surface providing a non-slip grip. Each screwdriver is individually tested to 1,000V in accordance with VDE 0680. The overall length is 180mm with a blade length of 80mm and with 3.5mm tip for slotted screws.
EAN Barcode | 4006274223929 |
- Standard Delivery* - £1.99
