Save yourself time and money with the Restorer Tool; an efficient way of removing material, that would normally require the use of many different hand and power tools. The 420W, handheld tool is highly versatile; it can be used to buff, sand, grind, polish and clean many different surfaces including wood and metal, using the varied roller accessories. Simply change the drum using the tool-free, quick release function, to suit your chosen application. It is compact and neat for accessing tight or awkward areas, and can be used on flat, curved, wet or dry surfaces. The Restorer Tool is especially useful for furniture restoration.
Working like a drum sander the 75mm diameter x 100mm width drum is fast and effective with the chosen accessory for your task. Variable speed allows for greater control. It has a comfortable handle to ensure for a supported grip, plus has a front palm grip meaning you can work vertically or overhead with ease. It evenly distributes pressure across the tool, to allow for enhanced control and to reduce strain on your hands.
Additionally, it has a dust extraction outlet so you can easily attach a vacuum source to the output port to safely remove debris and we would always recommend a dust extractor is connected on this tool. The lock-on switch ensures power is maintained during use, whilst the variable speed dial allows you to choose your speed to accommodate for touch-ups or total renovation tasks.
Supplied with the Restorer Tool, a strong carry bag, 1 x 46 grit rust/paint removal roller, 1 x 80 grit abrasive sleeve, 1 x 120 grit abrasive sleeve, 2 x 60 grit sanding sleeves, 2 x 80 grit sanding sleeves, 2 x 120 grit sanding sleeves.
No Load Speed 1,000 - 3,200 rpm
Rating Home/Light Trade
Corded or Cordless Corded
Cable Length 4.8 m
Motor Power 420 W (230 V)
Plug Fitted UK 3 pin plug
Web Attribute Set Sander Polishers
