PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our Newcastle store.
High quality European made machine, built to last.
Choice of cutter blocks, HSS, Tersa or Spiral
Contact our Business Team to discuss your requirements
Get years of service from this solid and precise machine - ideal for a busy professional workshop.
Fine ground cast iron tables
Timber will pass smoothly over this 1870mm fine ground cast iron table. The cast iron reduces vibration and will ensure flatness and accuracy even with demanding use.
Single lift tables
Save time and effort thanks to the single lift tables, aided by large hinges with torsion springs. Easily switch from planing to thicknessing; plus, get set up quickly and easily as the fence can stay in place.
Cast iron fence with aluminium fence plate
Timber is easily squared with this durable and robust cast iron fence, which tilts 90⁰-45⁰.
Tersa or spiral cutter blocks
Tailor to your needs with either a four-knife block with re-sharpenable HSS knives, a three-knife Tersa block for quick changes with no extra set up, or the latest spiral cutter block for a clean finish and reduced sanding time.
Generous capacity
The MSP 315 has a thicknessing capacity of 400mm x 230mm and a 410mm planing width, making this machine hugely useful within a professional workshop environment.
European made
From their production plant in the Czech Republic, ROJEK is a major global manufacturer. With over 100 years of experience in the industry, the ROJEK name is synonymous with high quality machinery.
Thought about leasing?
There is a range of finance options to make investing in machinery simple, affordable, and tax efficient.
The ROJEK MSP 415 is an industrial planer thicknesser with single lift cast iron tables. Large hinges with torsion springs make it easy to handle the cast iron tables when changing from one function to the other. This machine also has the advantage of a separate feed motor allowing two speeds (on the 3 phase version). It has a large 410mm planing width and a 400 x 230mm thicknessing capacity. This machine is ideal for a modern and busy professional workshop and will give years of service.
The MSP 415 is available with either a four-knife block with resharpenable HSS knives, a three-knife Tersa block for easy changes or the latest spiral cutter block. Other options such as additional rollers and a wheel kit are available to tailor the machine to particular requirements.
The MSP 415 is a high quality European made machine, built to last. The MSP 415 is available with either 240V single or 415V three phase motors. Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
This product is classified as a Large Delivery
product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact
you upon completion of your order to discuss carrier options and arrange a
delivery date to suit you.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
