Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The AP340E dust extractor features a thoroughly modern design and twin cartridge filters. High performance comes from careful matching of the motor, impeller and housing. The result is a quietly efficient and powerful machine able to extract from almost all machinery found in a typical large workshop.
It has a single 200mm inlet and includes a twin 150mm adaptor. The 500mm diameter, 600mm high cartridge filters have a rating of 1 micron @ 100% capture rate. The cartridge filters increase the potential use of this machine to include sanders as well as the normal range of saws, planers etc. Being polyester the filters are easy to keep clean with the top mounted crank handles. With a large filter surface area of 3.6m² the general airflow is not reduced. A comfortable tubular handle, steel rear wheels and two pairs of castor wheels provide easy mobility. Large capacity plastic waste sacks and quick release straps are included.
Overall, a fine, modern extractor for any trade workshop.
Hose not supplied.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Palletised Large Delivery service.
A specialised palletised goods carrier that will deliver to kerbside only.
The carrier will be in contact to confirm the delivery date.
UK Mainland - £70
UK Remote & Offshore* - charge advised in basket
