Guarantees an even firmer hold for your tool. The drive recess enables the bit to be applied with optimal force transmission - even when working overhead!
MULTI head
Innovative pocket segments help with every application. On wood, they have a milling effect, and on metal, they function like a brake to prevent over-tightening.
Ground Serrations
Allow for a quick and secure fastening to be achieved. The uniquely ground thread, which runs into the front flanks of the thread, has the advantage of being able to cut through the fibres of the material more easily.
4CUT
The point significantly reduces wood splitting and pre-drilling is made unnecessary for most wood types. The insertion moment is also effectively reduced. The cutter on the thread run-out expands the wood even more and the thinner shank no longer produces friction. This keeps the torque low and saves energy. This means more fastening with a single battery charge.
These screws provide the perfect solution for the fast and efficient laying of chipboard and timber flooring. The unique thread design pulls the parts tightly together. The T star heads will give a positive drive and the carefully designed threads help to hold the two materials together tightly eliminating squeaky floors. The lower part of the thread has a SPAX 4-CUT point for fast penetration without the need to pre-drill. WIROX coated for maximum corrosion protection, 60mm long and 4.5mm diameter. Tub of 300.
