Stanley FatMax Tenon Saw 11tpi - 300mm
- Online exclusive
- 300mm blade with reinforced back; bi-material handle for improved grip
- Extra long life induction hardened triple edge tooth design
- Fine 11tpi ideally suited to mitre or joint work
With a fine 11tpi, this tenon saw is ideally suited to mitre, or joint work where a smooth finish is highly desirable. Extra rigidity makes for a straighter cut and the long life induction hardened teeth, which cut on both the push and pull stroke, make this saw exceptionally good value for money. The bi-material handle, for improved grip, is screwed to the blade for extra strength and incorporates a 45° and 90° reference point.
EAN Barcode | 3253565171990 |
Tooth Pitch \ tpi | 2.31 mm \ 11 tpi |
- Standard Delivery* - £1.99
*UK Mainland only. Order before 3pm for Next Day Delivery. Additional charges may apply for remote or offshore areas.
