Stanley FatMax® Compound Action Long Nose Pliers 200mm
- Dual pivot gives 70% increase in gripping/cutting power
- Carbon steel, heat treated jaws for durability
- Ergonomic, bi-material soft grip handles for comfort
Stanley FatMax® Compound Action Combination Pliers 215mmFrom £18.10 £15.08
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
These Compound Action Long Nose Pliers feature a dual pivot design giving 70% more gripping and cutting power than standard single pivot pliers. The dual pivot means they require far less effort making any task that much easier. The jaws open to a maximum 75mm, the tip size is 2.9mm giving excellent access in tight spots.
As with all FatMax these tools are designed for professional trades. They are made to be durable and make the job easier. The ergonomic handles have bi-material non-slip grips for comfort and safety. The jaws are high-carbon steel, heat treated and carefully ground to give a high level of performance.
EAN Barcode | 3253560708122 |
Plier Size | 200 mm |
- Standard Delivery* - £1.99
