PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Made specifically for the UJK Professional Router Table, this extension provides vital extra support when machining wide workpieces such as raised panels for cupboard doors. It is 810mm in length, running along the entire front edge of the table.
Fixing is just a simple matter of attaching a bracket on either side, on the underside of the table using 3 cap-head screws per side. The extension slides in and out of the brackets, on strong rectangular section bars. Going from zero to 260mm, at its maximum, it effectively gives you approximately 610mm from the centre of the router cutter to the edge of the extension. The top edge of the extension is a low friction material, ensuring that your work glides smoothly.
For the UJK Professional Router Table
Provides vital extra support when machining raised panels
810mm long, telescopes from zero to 260mm
Effectively gives 610mm from the centre of the cutter
Low friction material top edge ensures work glides smoothly
Simple to attach, strong rectangular section support bars
