UJK Three Wing Rebate Cutter & Imperial Collar
From £119.98 £99.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • British-made and designed to deliver precision, durability, longevity
  • Features ground breaking Internal Bearing Technology (IBT) offering superior running balance and protection from dust and debris
  • Features a unique three-wing design with replaceable blades
  • Produces straight and curved rebates with a clean, ‘glass-like’ finish
  • Made from stainless steel, making it resistant to corrosion
  • Solid carbide, double-edged replaceable blades
  • Specifically designed for use with router tables
  • Available in 1/2" and 12 mm shanks
  • Supplied with UJK orange imperial depth discs, rebate depth produced 1/16", 1/8", 3/16", 1/4", 5/16",5/8", 3/8", 7/16", 1/2", 9/16"
The UJK Rebate Router Cutter is a new, innovative design of the much-loved rebate router cutter. British-made and designed to deliver precision, durability, longevity, and smooth, clean cuts, it is a worthy addition to any workshop.
While rebates are often used on spindle moulders, this cutter is specifically designed for use with router tables. The UJK Three Wing Rebate Cutter offers a unique three-wing design with replaceable blades, effortlessly producing straight and curved rebates and delivering a ‘glass- like’ finish. Available in 1/2" and 12 mm shanks.
UJK have created truly ground breaking technology with Internal bearing technology (IBT) featuring in both sizes of the rebate cutter. The IBT allows the twin bearings to sit low in the cutter, offering a superior running balance and protection from dust and debris, resulting in a smoother cutter and longer lifespan.
The British-made and one of its kind made from stainless steel, making it resistant to corrosion. The solid carbide, double-edged replacement cutters are held securely in place by Torx screws, ensuring they remain secure. The cutter sits in two points of positive register, providing maximum accuracy.
Supplied with imperial UJK orange depth discs.
Imperial depth discs, rebate depth produced 1/16", 1/8", 3/16", 1/4", 5/16", 5/8", 3/8", 7/16", 1/2", 9/16".
1/2" shank supplied with an imperial bush.
12mm shank supplied with a metric bush.
Overall Length: 87 mm
British Made British Made
