From £478.98 £399.15
In Stock
- get it Tuesday 28th Mar, order within and choose Premium delivery. Delivery info
  • Micro-adjustable fence and depth stops
  • Adjustable scoring spurs for cross-grain work
  • Makes grooves as narrow as 1/8" up to 1" wide rebates
Customers Also Bought
Total:
£836.22 £696.85
Originally created to replace innumerable wooden moulding and joinery planes, early combination planes were often over complicated and difficult to set up. However, a combination plane can be invaluable for restoration work and an ideal choice when you need to make a short run of moulding. It is often easier than taking the time to set up a machine.
Veritas designed their combination plane from the ground up to eliminate problems that made using the originals so frustrating. This modern example is precisely machined, quick to adjust and holds its settings securely.
The straight cutters used together with the fence mean it can tackle fundamental joinery such as rebates, tongues and grooves. With a homemade wooden guide, the plane can cut through dadoes. To prevent tear-out in cross-grain work, adjustable scoring spurs on both the main body and sliding section score the grain ahead of the blade.
The two-part design (a main body and separate sliding section) lets you accommodate blades of different shapes and sizes to make cuts ranging from grooves as narrow as 1/8" up to 1" wide rebates. The sliding section adds stability and support to the blade, and clamps securely in place on stainless-steel rods. You can position the fence on either side, allowing you to use the plane left or right handed to accommodate grain direction. The plane comes with 2 pairs of fence rods (125mm and 200mm). A micro-adjust thumbscrew allows you to fine-tune the position of the fence. The depth stops on the body and sliding section also have threaded adjustment.
A 1/4" straight blade is included with the plane, and a selection of blades for grooving, rebating, beading, reeding, and fluting are available separately.
You can use the blades individually or in sequence to create a variety of decorative profiles, from simple to complex, from furniture edge treatments to architectural details.
The 45° blade bed can also hold any of the right-hand blades of the Veritas small plough plane. It also accepts Record 405 and Stanley 45/55 blades.
The plane is 267mm long and weighs 1.8kg. Made of stress-relieved ductile iron with brass fittings with a torrefied maple tote and fence facing.
  • Stress-relieved ductile iron, brass fittings and torrefied maple tote
  • Accepts Record 405 and Stanley 45/55 blades
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.70 6
