Veritas Miniature Low Angle Block Plane
- Weight only 48g, 60mm long by 19mm wide
- Fully functional, easy to manoeuvre and control
- Cast stainless steel body
- Accurately machined and surface ground
- Stainless steel Norris-style adjuster
- A2 tool steel blade (1.5mm thick)
- Supplied in a French-fitted embossed leatherette box
- Made in Canada
This version of the Veritas low angle block plane is about a third the size of the original. At just under 60mm long and 19mm wide, it is a useful size for small-scale work or where a larger plane would be difficult to use. The low 12° bed angle combined with the 25° blade bevel gives it a cutting angle of 37°, making it also suitable for end-grain use. The stainless steel Norris-style adjuster lets you set the 12.7mm wide A2 blade with precision. The body is made from investment-cast stainless steel, and has a fixed mouth, machined sides and a ground sole. Weighs 48g. Made in Canada. Supplied in a French-fitted embossed leatherette box.
EAN Barcode | 722356012338 |
Nett Weight | 48 g (1.7oz) |
Plane Blade Width | 12.7 mm (1/2") |
Plane Sole Length | 63.5 mm |
- Standard Delivery* - Free
