Veritas Standard Block Planes
- Excellent plane for general purpose work
- Comfortable to hold with a nice weight and balance
- Effective cutting angle of 45°
- Supplied with a PM-V11 tool steel blade
The standard block plane is preferred for general purpose work. The 20° bed angle plus the blade's 25° bevel angle results in an effective cutting angle of 45°. The low profile lever cap fits the hand well, at only 3.2mm higher than its low angle variant (weight 790g(1.3/4lb)). In all other respects, it is the same as the low angle block plane. Included is a lapped blade, 41mm wide and PM-V11 tool steel blade are available. The lapped blades have a flatness tolerance of ±0.005mm or better over the working surface and with an average roughness surface finish of 0.000127mm(5 micro inches) or better.
| EAN Barcode | 5052511076376 |
| Nett Weight | 795 g (1lb 12oz) |
| Plane Blade Type | PM-V11 |
| Plane Blade Width | 41 mm (1.5/8") |
| Plane Sole Length | 165 mm |
- Standard Delivery* - Free
