Veritas Tapered Tenon Cutters
From £59.18 £49.32
9 Reviews
  • For putting tapered tenons on turnings, dowels or rustic furniture components
  • Straight-edged blade tapers the ends
  • Size given is the minimum tenon diameter; the max is 1/2" greater
  • The curved blade (for dowel making) should be used with only the smallest sizes
Veritas tapered tenon cutters will put tapered tenons on the tips of turnings, dowels or rustic furniture components to fit into tapered holes; for example, legs and spindles on a Windsor chair. Use the cutter like a hand-held pencil sharpener; you either rotate the workpiece while pressing it into the cutter body or you can rotate the tool on the workpiece. Works equally well in soft, green or hard woods. Although the body design is similar to our Veritas dowel and tenon cutters, the cut is quite different. When a tenon is fed through the body, the straight-edged blade tapers the ends, whereas the curved blade on our dowel cutters cuts cylindrical tenons with a radiused shoulder. (If you have already purchased our dowel cutters, buying a straight replacement blade will allow you to cut tapered tenons.) Please note; the curved blade (for dowel making) should be used with only the three smallest sizes of tenon cutters.
The size given for each cutter is the minimum tenon diameter it will cut; the maximum is 1/2" greater, over a total tenon length of 63mm(2.1/2"). Some longer tenons may require cutting the major diameter with a larger cutter, and then finishing with a smaller cutter.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
5 9
