Yorkshire Grit Microfine
- Super fine abrasive paste designed for woodturners
- Enhances the overall appearance of the wood
- Achieve a high quality finish
- Fine abrasion without fine dust
- Blend of natural waxes, oils with fine abrasive
- Made in U.S.A
Easy Wood Tools Full-Size Easy Turning™ Set 3-PieceSpecial Price £289.82 £241.52 was £362.28 £301.90 Save £72.46 £60.38
Easy Wood Tools Mid-Size Easy Turning™ Set 3-PieceSpecial Price £239.98 £199.98 was £299.98 £249.98 Save £60.00 £50.00
Easy Wood Tools Easy Micro Tools™ 3-Piece SetSpecial Price £198.70 £165.58 was £248.38 £206.98 Save £49.68 £41.40
Yorkshire Grit is an abrasive paste used by woodturners across the world. Available in both Microfine (for resins/hybrids/wood) and Original (for wood), it’s known for its effectiveness in enhancing the surface of wood and achieving a smooth, polished finish.
Yorkshire Grit Microfine is an advanced abrasive paste designed for woodturners to achieve an exceptionally smooth and fine surface finish on wooden surfaces. The abrasive paste gives a fine keyed surface to your woodturning projects before adding a final finish. The products contain an ultra-fine, hand-blended mix of mineral oil, beeswax and abrasive powders that are carefully processed together without the use of solvents or other strong smelling and potentially harmful chemicals. The result is a creamy paste that acts like “liquid sandpaper” which reduces scratches left behind by lower grit dry sanding, and eliminating fine dust produced by higher grit sanding.
Made in the U.S.A
EAN Barcode | 811269021466 |
Pack Size | 227 g |
- Standard Delivery* - £1.99
