Easy Wood Tools Full-Size Easy Turning™ Set 3-Piece
109209
From ÂŁ362.28 ÂŁ301.90
5 Reviews
Delivery
Free Standard Delivery*.
Estimated stock arrival in 5 weeks.
  • Ideal for spindles, table legs, large bowls, platters etc
  • No need to sharpen;, simply rotate cutter to a fresh edge
  • Solid carbide replaceable tips keep an edge many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 8mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
Big tools, for big projects
When it's spindles, large bowls or table legs your tackling, then the Easy Wood Tools Full-Size range is just what you need. Larger tools to tackle bigger projects, the 16-inch handles give you greater leverage and support making them ideal for those turning larger workpieces.
  • Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
  • All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
  • The range features three cutting types with colour coded handles to make your turning easy from start to finish
Full-Size Easy Rougher
Remove bulk material quickly and efficiently.
Full-Size Easy Finisher
For creating curves and for final shaping.
Full-Size Easy Detailer
For precision details - micro coves, beads, and finer details.
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
  1. Easy Wood Tools Full-Size Easy Turning™ Set 3-Piece
Total:
ÂŁ456.32 ÂŁ380.27
Easy Wood Full-Size Easy Tools are ideal when it comes to turning spindles, table legs, large bowls and other similar projects. He longer handle offers greater control when working on larger projects
This 3-piece set comprises one of each tool:
The Easy Wood Full-Size Easy Rougher has a square cutter, it removes material quickly, cleanly and efficiently.
The Easy Wood Full-Size Easy Finisher with its round cutter, produces coves, hollows, sweeping curves and aids final shaping.
The Full-Size Easy Detailer helps create small coves, beads, and other fine details. It has a diamond shaped cutter.
The 406mm long handle is American Maple with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 12.7mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 622mm. The shaft is engraved with the corresponding carbide cutter reference number.
4.80 5
