Easy Wood Tools Full-Size EASY FINISHER™
- Ideal for large bowls, table legs, platters and bigger projects
- Finisher for coves, hollows, sweeping curves and final shaping
- No sharpening required - rotate the carbide cutter to a fresh edge
- Solid carbide cutter stays sharp many times longer than HSS
- Suitable for dry or green wood, acrylics, and resin
- 12.7mm square section bar sits flat and steady on the tool rest
- 406mm American Maple handle, copper ferrule for strength and leverage
- Easy Wood Tools are 100% made in the USA
Big tools, for big projects
When it's spindles, large bowls or table legs your tackling, then the Easy Wood Tools Full-Size range is just what you need. Larger tools to tackle bigger projects, the 16-inch handles give you greater leverage and support making them ideal for those turning larger workpieces.
- Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
- All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
- The range features three cutting types with colour coded handles to make your turning easy from start to finish
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
Easy Wood Tools Lexan™ Chip Deflector - 1/2"Special Price £30.38 £25.32 was £31.98 £26.65 Save £1.60 £1.33 -
Easy Wood Tools Ci0-NR Carbide Cutter - Round Negative RakeSpecial Price £21.35 £17.79 was £22.48 £18.73 Save £1.13 £0.94 -
Easy Wood Tools Ci0 Carbide Cutter - RoundSpecial Price £18.98 £15.82 was £19.98 £16.65 Save £1.00 £0.83 -
Axminster Stainless Steel Metric Rule - 300mmSpecial Price £2.95 £2.46 was £3.28 £2.73 Save £0.33 £0.27 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
The Easy Wood Tools Full‑Size Easy Finisher™ is a carbide woodturning tool designed for refining curves, smoothing hollows, and producing clean final shapes on large bowls, spindles, table legs, platters, and other substantial projects. As part of the Full‑Size range, it offers maximum leverage and extended reach, making it ideal for finishing work on bigger, heavier workpieces.
Featuring a replaceable round carbide cutter and a sturdy 12.7mm square section bar, the Full‑Size Easy Finisher™ stays flat and stable on the tool rest, giving you predictable control with no sharpening required. Its 406mm American Maple handle provides superior leverage and balance, allowing turners to work comfortably when smoothing wide curves or refining deeper areas.
The Full‑Size Easy Finisher™ is engineered to deliver smooth, flowing cuts that refine the form and prepare it for sanding. It excels at blending curves, shaping hollowed areas, and cleaning up the interior and exterior of large bowls. When the tool is held parallel to the floor at centre height, the square bar keeps the tool steady and greatly reduces the risk of catches or snatches, even when working on wide or heavy blanks. Its combination of weight, reach, and cutter geometry makes it highly effective for controlled finishing on substantial workpieces.
With no sharpening needed, simply rotate the cutter to a fresh edge when dull. Easy Wood Tools’ premium solid carbide lasts many times longer than HSS and is suitable for turning dry or green wood, acrylics, and resin. All Easy Wood Tools are 100% made in the USA.
What you get
Round carbide cutter fitted as standard
Hex key for easy cutter rotation or replacement
406mm American Maple handle with copper ferrule for strength
12.7mm square section bar for maximum stability on the tool rest
Colour‑coded handle for quick identification within the range
Shaft engraved with the carbide cutter reference number
Specifications
Overall length: 622mm
Handle length: 406mm
Bar profile: 12.7mm square
Optional upgrade
Negative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, producing a finer, smoother finish on timber when refining shapes and performing final cuts.
| Chisel Blade Length | 216 mm |
| EAN Barcode | 5052511133390 |
| Handle Length | 406 mm |
| Overall Length | 622 mm |
| Replacement Tip | Ci0 (109258) |
- Standard Delivery* - Free
