Easy Wood Tools Ci4-NR Carbide Cutter - Diamond Negative Rake
109263
From £24.18 £20.15
3 Reviews
Dispatching Soon
- Email me when available
Delivery
  • Fits: Easy Start Easy Detailer, Mini Easy Detailer
  • Fits: Mid-Size Easy, Full Size Easy and Pro Easy Detailers
  • 9.4mm wide, solid carbide
  • Negative rake for acrylics, resin and very hard woods
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
  1. Easy Wood Tools Ci4-NR Carbide Cutter - Diamond Negative Rake
Total:
£87.42 £72.85
The Ci4-NR solid carbide, negative rake tip is diamond shaped, 9.4mm wide. It fits the Easy Start Easy Detailer, Mini Easy Detailer, and Mid-Size Easy Detailer, Full Size Easy Detailer and Pro Easy Detailer.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
5.00 3
