Easy Wood Tools Mid-Size Easy Turning™ Set 3-Piece
- The perfect go-to tools for bowls, platters, boxes and spindles
- No need to sharpen;, simply rotate cutter to a fresh edge
- Solid carbide replaceable tips keep an edge many times longer than HSS
- Use to turn dry or green wood, acrylics and resin
- 8mm square section bar ensures the tool sits flat and steady
- American Maple handle with copper ferrule for strength
- Easy Wood Tools are 100% made in the USA
Go-to tools for any turner
A versatile set of tools for a range of turning projects. Whether it bowls, platters or boxes, the Easy Wood Mid-Size range is the perfect go-to tool to keep your turning on track
- Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
- All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
- The range features three cutting types with colour coded handles to make your turning easy from start to finish
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
The Easy Wood Tools Mid‑Size Easy Turning™ Set 3‑Piece provides a complete solution for general woodturning, combining the three essential tools needed for shaping, refining, and detailing across a wide range of projects. Including the Mid‑Size Easy Rougher™, Easy Finisher™, and Easy Detailer™, this set is ideal for working on bowls, platters, boxes, spindles, and other everyday turning tasks.
Each tool in the set features a replaceable carbide cutter and a 9.5mm square section bar that sits flat and steady on the tool rest, making them intuitive and easy to control.
The Mid‑Size range offers the perfect balance between reach and handling, providing enough leverage for larger work while remaining precise and comfortable to use.
With no sharpening required, it simplifies the turning process and allows you to focus on technique rather than tool maintenance.
Working together as a complete system, the three tools guide you through the full turning process. The Rougher™ quickly removes material to establish shape, the Finisher™ refines curves and smooths surfaces, and the Detailer™ adds crisp definition and decorative features.
When used parallel to the floor at centre height, the square section bar keeps each tool stable on the rest, helping to reduce catches and deliver predictable, controlled cuts. This makes the set equally suitable for those developing their skills and experienced turners working on a variety of projects.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Set includes: Mid‑Size Easy Rougher™, Easy Finisher™, Easy Detailer™
Cutter types: Square, round, and diamond carbide cutters
Range: Mid‑Size (versatile tools for everyday turning)
Bar profile: 9.5mm square section for stability on the tool rest
Handles: American Maple with copper ferrules
Overall length: 533mm.
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to produce a smoother finish and improved control on more delicate or challenging materials.
| Chisel Blade Length | 178 mm |
| EAN Barcode | 5052511133475 |
| Handle Length | 350 mm |
| Overall Length | 533 mm |
- Standard Delivery* - Free
