Easy Wood Tools Mid-Size Micro EASY DETAILER™
109280
Special Price £114.94 £95.78 was £120.98 £100.82 Save £6.04 £5.03
2 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Wednesday 5th Aug
  • Versatile go‑to detailing tool for bowls, platters, boxes and spindles
  • Micro detailer for small coves, delicate beads, and ultra‑fine details
  • No sharpening required - simply rotate the carbide cutter to a fresh edge
  • Solid carbide cutter keeps an edge many times longer than HSS
  • Suitable for dry or green wood, acrylics and resin
  • 9.5mm sq section bar sits flat and steady on the tool rest for easy control
  • 350mm American maple handle, copper ferrule for strength and leverage
Go-to tools for any turner
A versatile set of tools for a range of turning projects. Whether it bowls, platters or boxes, the Easy Wood Mid-Size range is the perfect go-to tool to keep your turning on track
  • Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
  • All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
  • The range features three cutting types with colour coded handles to make your turning easy from start to finish
Mid-Size Easy Rougher
Remove bulk material quickly and efficiently.
Mid-Size Easy Finisher
For creating curves and for final shaping.
Mid-Size Easy Detailer
Create fine details such as small coves and beads.
Mid-Size Micro Easy Detailer
For precision details - micro coves, beads, and finer details.
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
The Easy Wood Tools Mid‑size Micro Easy Detailer™ is a carbide woodturning tool designed for creating small coves, delicate beads, and ultra‑fine decorative details on bowls, platters, boxes, spindles, and other projects.
Offering greater reach and stability than the micro range, but finer precision than the standard Mid‑size Detailer, it is the ideal go‑to tool for intricate finishing work on larger workpieces.
Equipped with a replaceable carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑size Micro Easy Detailer™ delivers exceptional stability and easy, predictable control with no sharpening required.
The extended 350mm American maple handle gives added leverage and balance, making delicate cuts feel safer and more controlled - even on deeper or larger forms.
Purpose‑built for intricate detail work, this tool excels at producing clean, consistent ultra‑fine details with minimal effort.
With the tool held parallel to the floor at centre height, the square bar keeps the tool flat on the rest, helping to virtually eliminate catches and snatches - ideal for delicate finishing cuts on both spindles and faceplate work.
With no sharpening needed, simply loosen the fixing screw and rotate the cutter to a fresh edge when dull.
Easy Wood Tools’ long‑lasting carbide holds an edge many times longer than HSS and can be used on dry or green wood, acrylics, and resin.
Each shaft is engraved with its carbide cutter reference number for quick identification.
What you get
Carbide cutter optimised for ultra‑fine detail
Hex key for quick cutter rotation or replacement
350mm long American maple handle with copper ferrule for strength
Colour‑coded handle for easy identification across the range
Specifications
Overall length: 533mm
Bar profile: 9.5mm square section
Optional upgrade
Negative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin materials, producing a smoother, finer finish on timber as skills develop.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
5 2
