Easy Wood Tools Mid-Size EASY ROUGHER™
- Versatile go‑to roughing tool for bowls, platters, boxes and spindles
- Removes material quickly, cleanly and efficiently
- No sharpening required - simply rotate the carbide cutter to a fresh edge
- Solid carbide cutter keeps an edge many times longer than HSS
- Suitable for turning dry or green wood, acrylics, and resin
- 9.5mm sq section bar sits flat and steady on the tool rest for easy control
- 350mm American maple handle, copper ferrule for strength and leverage
- Easy Wood Tools are 100% made in the USA
Go-to tools for any turner
A versatile set of tools for a range of turning projects. Whether it bowls, platters or boxes, the Easy Wood Mid-Size range is the perfect go-to tool to keep your turning on track
- Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
- All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
- The range features three cutting types with colour coded handles to make your turning easy from start to finish
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
The Mid‑Size Easy Rougher™ is a carbide woodturning tool designed for rapid, controlled material removal when turning bowls, platters, boxes, spindles, and larger projects.
Offering increased reach and versatility over the Easy Start range, it is a reliable go‑to tool for turners looking to tackle a broader range of work with confidence.
Featuring a replaceable carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑Size Easy Rougher delivers excellent stability and easy control with no sharpening required.
The longer handle provides improved leverage and comfort, making it ideal for bowl and faceplate turning, while remaining intuitive and predictable for turners transitioning from smaller tools.
The Mid‑Size Easy Rougher removes material quickly, cleanly and efficiently, helping establish shape with minimal effort on larger blanks.
The square section bar ensures the tool remains flat and steady on the tool rest, and when used parallel to the floor at centre height, the risk of catches and snatches is virtually eliminated, supporting smooth, controlled roughing cuts.
With no sharpening needed, maintenance is simple - when the edge becomes dull, just loosen the fixing screw and rotate the cutter to a fresh edge.
Easy Wood Tools’ long‑lasting carbide cutters keep an edge many times longer than HSS and are suitable for turning dry or green wood, as well as acrylics.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
What you get
Square carbide cutter fitted as standard
Hex key for easy cutter rotation or replacement
350mm American maple handle with copper ferrule for added strength
Colour‑coded handle for easy identification within the Easy Wood Tools range
Specifications
Overall length: 533mm
Bar profile: 9.5mm square section
Optional upgrade
Negative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, while also producing a finer, smoother finish on timber as skills develop.
| Chisel Blade Length | 178 mm |
| EAN Barcode | 5052511133376 |
| Handle Length | 350 mm |
| Overall Length | 533 mm |
| Replacement Tip | Ci2-SQ (109254) |
- Standard Delivery* - Free
