Easy Wood Tools 3/16" Negative Rake Beading Cutter
- Top tips for turning tools
- Turns an Easy Rougher into a multi-use tool
- Fits: Easy Start, Mini Easy & Mid-Size Easy Roughers
- Long lasting solid carbide
- Negative Rake for smooth cuts on woods and resins
- Add a perfect semi-circular bead to any project
- Repeated beads are even and equal
Easy Wood Tools Mini EASY ROUGHER™Special Price £92.03 £76.69 was £96.88 £80.73 Save £4.85 £4.04 -
Easy Wood Tools Easy Start EASY ROUGHER™Special Price £60.31 £50.26 was £63.48 £52.90 Save £3.17 £2.64 -
Easy Wood Tools Mid-Size EASY ROUGHER™Special Price £109.61 £91.34 was £115.38 £96.15 Save £5.77 £4.81 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axminster Stainless Steel Metric Rule - 300mmSpecial Price £2.95 £2.46 was £3.28 £2.73 Save £0.33 £0.27 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75
Top tips for turning tools. This negative rake carbide tip will produce a perfect 4.8mmm (3/16") diameter semi-circular bead on any of your turning projects. The tip is made to fit the following Easy Wood Tools: Easy Start Easy Rougher, Mini Easy Rougher and Mid-Size Easy Rougher, which all take Ci2 size Easy Wood tips.
The negative rake on this profiling tip produces a smoother finish as the cutting action is less aggressive. It is effective on timber, as well as resins, acrylic, and other man-made materials. Producing a perfect bead could not be easier. It ensures that repeated beads are even and equal. Turn your Easy Rougher into a multi-use tool.
| EAN Barcode | 811269021480 |
| Tip Size | 4.8mm(3/16") |
- Standard Delivery* - £5
