Easy Wood Tools Ci3 Carbide Cutter - Round
- Fits: Easy Start Easy, Mini Easy and, Mid-Size Easy Finishers
- Fits: Full-Size Easy Rougher and Pro Easy Rougher
- Fits: Full-Size Easy Hollower #3 and all Pro Easy Hollowers
- 11.5mm diameter, solid carbide
- Optimum grade of carbide, long lasting cutting edge
- Proprietary grinding for the sharpest edge possible.
- Precision ground finish
- Easy Wood Tools tips are 100% made in the USA
Axminster Stainless Steel Metric Rule - 300mmSpecial Price £2.95 £2.46 was £3.28 £2.73 Save £0.33 £0.27 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75
The Ci3 solid carbide cutter is 11.5mm diameter. It fits the Easy Start Easy Finisher, Mini Easy Finisher, Mid-Size Easy Finisher, Full-Size Easy Hollower #3, Pro Easy Hollower #1, Pro Easy Hollower #2, and Pro Easy Hollower #3. Full-Size Easy Rougher and Pro Easy Rougher.
​The standard carbide cutters provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
| EAN Barcode | 811269020735 |
- Standard Delivery* - £5
