PROXXON FBS 240/E Precision Drill/Grinder Multi-Tool
410475
From £72.48 £60.40
In Stock
- get it Tuesday 14th May, order within and choose Premium delivery. Delivery info
  • Multiple uses; cuts, sands, polishes and grinds, etc.
  • 0.3-3.2mm keyless chuck
  • Variable speed
  • 2 inset rubber body grips
  • Permanent magnet motor
  • Maximum motor power 100W
  • Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories
  1. PROXXON FBS 240/E Precision Drill/Grinder Multi-Tool
Total:
£174.42 £145.35
Perfectly precise with PROXXON
- The 20mm Collar System
The 20mm collar range of PROXXON tools allows you to easily connect to one another and achieve maximum precision and versatility with your intricate tasks. Simply clamp the collar of your PROXXON drill or grinder to the drill stand, universal holder or router base and your tool is held steady whilst allowing you to take on a range of tasks including routing, engraving and drilling.
PROXXON Micromot Mb 200 Drill Stand
Enables bevelled drilling and versatile milling operations.
PROXXON MS 4 Machine Vice
Use with the drill stand.
PROXXON UHZ Universal Holder
Keep your tool stationary whilst you maneuver what you are working on.
PROXXON Router Base OFV
For slotting, milling grooves and milling edges.
The PROXXON FSB240/E is perfect for jewellers, mechanics, model builders, opticians, electronic enthusiasts and professionals. Can be used for prolonged periods when drilling, milling, die grinding, polishing, cleaning and engraving. This 100W multi-tool has a keyless chuck (0.3-3.2mm) to accept a wide range of accessories, well balanced and with variable speed for maximum control. The tool is well designed and the two inset rubber grips on the body ensure a good purchase, important for fine detail work. The permanent magnet motor is powerful and well balanced and the variable speed control gives a range of 5,000 to 20,000rpm. At the opposite end to the drill chuck is a hanging loop, used when the tool is coupled up to a flexible shaft. This tool has a quality specification, a flexible drive shaft with precision handpiece and 1.0mm, 2.4mm and 3.0mm collets is also available as an optional extra. Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories.
4.30 9
