Axcaliber Drawer Pull Cutter 2
- Cuts a clean, neat finger groove
- Removes the need to have protruding handles
- Use on drawers and cabinet doors
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/2" shank
Drawer pull cutters offer the opportunity to create flush fitting cabinet doors and drawers and are easier to use if used in a router table set-up. Drawer pull cutters remove the need to have protruding handles on your cabinets.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 38 mm (1.1/2") |
EAN Barcode | 5052511030668 |
R1 = Radius 1 | 6 mm |
R2 = Radius 2 | 1.6 mm (1/16") |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 22.2 mm (7/8") |
- Standard Delivery* - Free
