Axcaliber T-Slot Cutter for Track Clamps
- Use to cut a T-slot in a workbench or an assembly table
- Enables use of guide rail clamps as hold-downs
- Produce custom-made guide rails in hardwood
- Cut a T-Slots in nylon for home-made
- PTFE coating helps minimise resin build-up
- 1/2" shank
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
Looking like an overgrown keyhole cutter, you can use this cutter to cut a T-slot in a workbench or an assembly table. Once cut the T-slot enables you to use Axminster (or Festool) guide rail clamps as hold downs when working on a piece or gluing up. Alternatively a length of hardwood with a T-slot cut along its length can become a custom made or temporary guide rail. in addition, you can cut a T-Slot in nylon if making jigs to your own design. We suggest you remove the bulk of the waste with a straight cutter of the same diameter as the neck of the cutter (dimension E) prior to using the T-slot cutter.
Please note; When using this type of cutter it is recommended to use a small straight cutter first to remove some of the material and help prevent router overload.
C = Width of Groove | 6.5 mm |
D = Overall Diameter | 12.7 mm (1/2") |
E = Minor Diameter | 8.7 mm |
EAN Barcode | 5052511065011 |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 23 mm |
- Standard Delivery* - £1.99
