Axminster Engineer Series 4-Fluted Carbide End Mills
AX926549
AX926549
- Carbide end mills last longer and produce a quality finish
- Available in 3, 5, 6, 8 10, 12 and 16mm
- Designed to be held in an ER collet system
PROXXON FF 250/BL MICRO MillFrom £1,079.98 £899.98
Show more
Show less
These end mills are made from carbide; they last longer than standard high speed steel (HSS) cutters and produce an excellent finish. Carbide cutters like to be worked hard and, depending on the material, coolant is essential for quality of cut and life of cutter. They are available in 3, 5, 6, 8 10, 12 and 16mm. Please note: these cutters are designed to be held in an ER collet system.
