Axminster Workshop 8 Piece Detail Carving Tool Set
- 8 piece carving set
- Shapes include curved gouges, skew and flat chisels, V tool
- Overall length 150mm , blade length 25mm
Great quality and value for money
Kickstart your carving with this 8 piece detail carving set that offers, not only excellent value for money, but great quality too.
All you need
This flexible set offers a range of knives, not only perfect for creating intricate details on your workpiece, but also great for filling in on larger carving projects too. As well as for detailed work, this carving set can be used as carving tools for smaller workpieces.
A chisel for every cut
The complete set includes a range of curved gouges, as well as skew chisels, flat chisels, and a vee tool, to achieve a variety of cuts meaning you can attain perfectly carved results from start to finish.
Sharp from the start
The 4mm-8mm carbon steel blades are sharp and will withstand heavy usage, making this set perfect for beginners looking to carve straight out of the box. And at 150mm long, these chisels fit comfortably in the hand.
An excellent 8 piece set of small carving tools, very nicely made and great value for money. Although mainly intended for filling in detail work on larger carvings, they are equally useful for tackling small size carving projects. There is a useful range of shapes, curved gouges, skew and straight chisels and a Vee tool, and the edges are very sharp and will stand up well to heavy usage. The low price should make this set very attractive to beginners who might like to have a go at carving but are reluctant to invest too much at the outset. The overall lengths are 150mm, the blade lengths 25mm and the widths across the blades vary from 4 to 8mm.
EAN Barcode | 5052511003921 |
Set | 8 Piece |
- Standard Delivery* - £1.99
