Axminster Workshop Dust Extraction Adaptor - 100mm
502568
From £9.58 £7.98
  5. Half Star
16 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 7th May
  • Useful adaptor for sawbenches and router tables
  • Flanged 100mm adaptor with 62mm inlet
  • Accepts standard 100mm and 63mm hoses
  1. Axminster Workshop Dust Extraction Adaptor - 100mm
Total:
£40.97 £34.14
Router table set-ups and some sawbenches can sometimes present extraction problems, with extraction often required from both above and below the table. This adaptor enables you to achieve this by having a 100mm flanged outlet with a 62mm inlet at the top. A cabinet or enclosure will be required to extract from with a hole made to accept the adaptor. When extraction is connected using a standard 100mm hose, a separate 63mm hose can then be attached to the top of the adaptor and connected to either a dust port on the router table fence or the crown guard of the saw bench. We are sure there must be many other dust extraction situations where this fitting would prove invaluable.
4.40 16
