Axminster Professional Metric HSS 1-10mm x 0.5 Drill Set 19 Piece
106212
106212
From £40.38 £33.65
2 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 24th Jun
  • Made from M2 grade Swedish HSS, 1mm to 10mm x 0.5mm steps
  • Deep flutes ensure good chip clearance, drill point is 118°
  • Intended for general workshop and production use
  • Outside diameter tolerance of H8 within ISO 286 gives a close running fit
  • Supplied in a robust plastic case
  1. Axminster Professional Metric HSS 1-10mm x 0.5 Drill Set 19 Piece
Total:
£95.92 £79.93
The set comprises a selection of 19 excellent quality metric drill bits made from quality Swedish M2 grade steel and housed in a robust plastic case.
They have been heavily tested by our manufacturing department and are suitable for many materials up to and including hardened steels to HRC-30. These bits are ground from solid high speed steel bar and offer excellent chip clearance, rigidity and quality of cut.
Perfect for general workshop and production use, they are also available in a large range of metric and imperial sizes.
Remember to use coolant when appropriate.
Outside diameter tolerance of H8 within ISO 286. This gives a close running fit. Sizes range from 1-10mm in 0.5mm increments.
5.00 2
